Руководства по ремонту, разборке и устранению неполадок Apple iPad 10-го поколения, доступного в версиях с Wi-Fi и сотовой связью, с объемом памяти 64 или 256 ГБ. Выпущен в октябре 2022 года. Идентифицируется по номерам моделей A2696, A2757, A2777 или A3162.
Heating issue/screen brightness effected
Could it be possible to give me the dimensions of where the logic board is so I can place some heatsinks to try and keep ipad cooler so the screen don't keep reducing brightness. I'm sure it's a heat issue as once temperature is reduce the brightness of screen returns to normal.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
Here's a picture of the iPad 10 without the screen. I've marked out the logic board in the picture; basically if you cool the right edge of the iPad that's where the heat is going to be coming from.
The picture is oriented so you'd be looking at it with the charging port on the bottom.
Был ли этот ответ полезен?
Счет 4
2 Комментариев:
cheers. Planning to use akasa double-sided thermal conductive tape. I have plenty of small chipset blue heatsinks that should help handle the heat. Poor cooling design on expensive device. Apple solution is to close down apps to reduce processor usage which bring down heat.
из Поделиться
@robmods you might want to consider using a 0.3 mm Copper Shim Thermal Pads and some Kapton Tape with your heatsinks. Typically these are used for copper modding graphics cards, but I'm willing to bet that they would work really well in your iPad.
из Поделиться
Добавьте свой ответ
Robmods буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 14
За все время: 532
