Nintendo Game Boy Advance, выпущенная в 2001 году. Ремонт требует только стандартных инструментов и не требует нагрева.
How should I remove rust on the battery terminal?
Hello! I just bought this Game Boy Advance today and noticed that there was rust on the battery terminal. It still works fine, but the power indicator light flickers from green to red, probably because of the poor battery connection. It is only on this one terminal, so I want to try to clean it off. What is the best way to do this without damaging the motherboard? I could also replace the terminal but I would rather keep the OEM one.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Bex bw-100 electrical contact cleaner is a good option as well as 91% or higher isopropyl alcohol.
Oxo makes a slicone cleaning tool with a blade like nib and a brush that I highly recommend
Qtips are also a valid option
If there is any tough corrosion you can GENTLY pick and scrape at it with ifixit's sharp tweezers.
Был ли этот ответ полезен?
Счет 0
Instead of disassembling the terminal to replace it, you can also disassemble/clean/reassemble the OEM one, for example see this post from DigiKey or this one (it works for battery terminals in general). If you can't disassemble it, do not use liquids for cleaning (usually you don't want them near anything electronic) but something like a brush to remove as much "rust" as possible
Счет 0
Добавьте свой ответ
Bailey Bryan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 7
За последние 30 дней: 24
За всё время: 593
