Производительный ноутбук от Lenovo с 15,6-дюймовым экраном, выпущенный в 2016 году. Маркировка модели P500 расположена в левом нижнем углу рамки ЖК-дисплея.
Why is the screen blinking while on?
The Lenovo IdeaPad p 500 is blinking while it's been boot.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
If your Lenovo IdeaPad P500 laptop screen is blinking while it's turned on, it could be due to several reasons. Here are a few possible causes and solutions:
1. Graphics driver issue: Outdated or incompatible graphics drivers can cause screen flickering. Try updating the graphics driver to the latest version provided by Lenovo or the graphics card manufacturer. You can visit the Lenovo support website or the graphics card manufacturer's website to download and install the appropriate driver for your system.
2. Display settings: Incorrect display settings can sometimes lead to screen flickering. Right-click on the desktop and select "Display settings" or "Screen resolution" to access the display settings. Make sure the resolution and refresh rate are set correctly for your display. Try adjusting these settings and see if it helps resolve the issue.
3. Malware or virus infection: Malware or viruses can interfere with your system's functioning, including the display. Run a full system scan using a reputable antivirus program to check for any malware or viruses. Quarantine or remove any threats detected during the scan.
4. Hardware issue: In some cases, screen flickering can be caused by a hardware problem. It could be a loose connection between the display panel and the motherboard, a faulty display cable, or a malfunctioning display panel. If you suspect a hardware issue, it's recommended to contact Lenovo support or take your laptop to a professional technician for further diagnosis and repair.
5. External factors: Sometimes, external factors like improper power supply, electromagnetic interference, or lighting conditions can cause screen flickering. Try using your laptop in a different location or with a different power outlet to see if the issue persists. Additionally, adjust the display's brightness settings to ensure it's not too high or too low, which could contribute to flickering.
If the screen flickering issue persists after trying these solutions, it's best to reach out to Lenovo support or a qualified technician for further assistance. They will be able to provide specific troubleshooting steps or recommend appropriate repairs based on your laptop's model and configuration.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Morris Lloyd буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 18
За все время: 346
