Current limit when using it without battery installed
Has anyone used Surface Pro 4 without battery installed? I've got i5 model and the clock speed won't go up above 1.7Ghz when used without the battery installed. I tried using the device both with battery completely removed and with only battery control board installed and in neither cases seems to go above base clock..
I could install new battery but it's really easy for them to become "spicy pillow" and I've already replaced them once. Don't want to go into hustle of replacing them again.
Это хороший вопрос?
Счет 0
Добавить комментарий
