Fix the hold close part
Part that holds it close broke
Это хороший вопрос?
I’d first check whether the plastic tab itself broke or if the small spring/hinge piece just came loose.
If the tab is actually broken, the easiest repair is usually replacing the housing/locking mechanism, since gluing a stressed plastic latch often won’t hold for long. As a temporary fix, you could use a small piece of epoxy to rebuild the broken tab, but keep it away from the heated plates and moving hinge.
A photo of the broken area would make it much easier to tell what part is missing and whether it can be repaired.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 21
За всё время: 250
@amander post some good pictures of what is broken etc. so we can see what you see. Edit your question and use this guide Добавление изображений к существующему вопросу
из oldturkey03
Mera Remington stairtinger garm nhi ho raha
из Mishal Liaqat Bhatti
