usb connected, usb disconnected
when sometime i open my phone a notification shows usb connected/ usb disconnected and when i close my phone screen turns on again
ΠΡΠΎ Ρ ΠΎΡΠΎΡΠΈΠΉ Π²ΠΎΠΏΡΠΎΡ?
ΠΠ° ΠΏΠΎΡΠ»Π΅Π΄Π½ΠΈΠ΅ 24 ΡΠ°ΡΠΎΠ²: 1
ΠΠ° ΠΏΠΎΡΠ»Π΅Π΄Π½ΠΈΠ΅ 7 Π΄Π½Π΅ΠΉ: 3
ΠΠ° ΠΏΠΎΡΠ»Π΅Π΄Π½ΠΈΠ΅ 30 Π΄Π½Π΅ΠΉ: 14
ΠΠ° Π²ΡΡ Π²ΡΠ΅ΠΌΡ: 170
@nxtraptor does it do that all the times or only sometimes? Anything common when it happens? What have you checked? What have you tried to fix this?
ΠΈΠ· oldturkey03
Hi @nxtraptor,
Use a strong light and a magnifying glass to inspect the USB charge port for any bent or broken pins or if there's any debris lodged in the port enclosure.
If there is some debris, do not use a metal pin or probe to try and clear it. Try using a vacuum cleaner or a wooden toothpick instead.
ΠΈΠ· jayeff
