Руководства по ремонту и поддержка телевизоров Philips.
Persistent Backlight Problem with Philips 65PUS6554 12 TV
model : Philips 65PUS6554 / 12
Hello everyone,
I have a problem with my Philips 65PUS6554 /12 TV.
When the TV starts up, there is a flash and then a black screen. The sound still works.
It seems to be a backlight problem: I ordered an LED tester to check the LEDs, but all the LEDs are working properly.
After reassembling the TV, it worked for half a day before experiencing the same problem.
I first suspected a malfunction on the power supply board, so I ordered a new one. Once again, after replacing it, the TV worked for half a day before becoming faulty again.
I then ordered a new main board and a new T-con board, but once again the TV worked for half a day before becoming faulty again.
I've attached all the photos for reference, as well as a video of the flash phenomenon.
I also have a multimeter at my disposal, in case it can help.
I have to admit that I'm very desperate and don't know what else to do to solve the problem.
Thanks in advance for your help :)
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
@harqenzo There are now only two possibilities left. One is a bad panel (LCD driver boards) and the other possibility are the back lights. I have now had a few instances where they lit up with a tester but did not work from the power board. Check this quickly by shining a flashlight beam against the screen (in a darkened room) on a channel where you have sound. See if you can make out any shapes, silhouettes etc. If so, it is your backlight strips that need to be replaced.
A panel error usually still shows the backlight, just no video. OF course you can always try a tape-off AFTER the backlights.
Был ли этот ответ полезен?
Счет 0
Have you tested the led's with the multimeter? Remember they have a positive and negative side. Check them and if one is shorted you could bypass it with a jumper wire. There's a guy on YouTube with a video on how to do it. Personally I'd turn on the TV with the leds exposed and the screen disconnected and if they light up leave it on and see if they go out after half an hour.
Счет 0
The output voltage from backlight driver is 20% higher than the recommended voltage. This is VERY COMMON design of Philips tv. If u replace ALL backlight strips to brand new - then the tv will light up normal. However it may last 1 yr or less. If u reduce the backlight driver output voltage for recommended voltage - the backlight will last 7-8 yrs.
To reduce the backlight driver voltage - you need to tune the bias voltage at the BL IC - which is best left to experts.
Счет 0
Добавьте свой ответ
harqenzo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 13
За последние 30 дней: 48
За все время: 2,768
