Руководства по ремонту, разборке и устранению неисправностей для Apple iPad 9-го поколения с Wi-Fi, доступного с накопителем объемом 64 или 256 ГБ. Выпущен в сентябре 2021 года. Идентифицируется по номеру модели A2602.
Charging port not working
How do I find someone to replace a charging port on an iPad 9th generation?
It was working when it fell off the bed.
Это хороший вопрос?
Счет 3
Добавить комментарий
3 Ответов
Наиболее полезный ответ
First of all, if you're looking for suggestions you'll need to tell us where you're located, as this is a worldwide site and the answer will be very different depending where you are.
Until then, all I can say is you're not in a good position here. Apple did you dirty on the charging port of your iPad; not only is it attached directly to the motherboard so you can't just replace a part, but they also put it on a flex cable, making it even harder to replace. So it's going to take a fairly skilled technician to be able to do the specialized soldering required to fix your port.
You can always do a search for local repair facilities and contact them. Ask whether they have the expertise to repair your port, and what the cost is.
Был ли этот ответ полезен?
Счет 2
it stopped working then i had to fix the charging port.
Счет 1
1 Комментарий:
Same. I Suggest To get an IPAD 9 Lightning Replacement.
из
ipad 9 no charging flex change ic change no charging
Счет 0
Добавьте свой ответ
Dan Frain буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 11
За последние 30 дней: 35
За всё время: 1,789
