Why is my laptop beeping continuously?
I tried to turn on my laptop and found my laptop beeping continuously.What should I do to fix it?
Это хороший вопрос?
Это хороший вопрос?
You should try checking with this HP guide. Your problem might vary from a dead CPU, to a simple reset. I've had similar issues with some Lenovo machines and the issues was solved with a simples reseat of the RAM. Good luck.
Был ли этот ответ полезен?
None of them helped
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 46
За все время: 571
4 Комментариев
Hello, are the beeps in a sequence by chance, or is it just one long beep? If it is a sequence if you could count the beeps and reply that would be great!
из BurtBen Поделиться
No it's actually beeping like a car's blinker
из Jackson King Поделиться
Could you possibly record it and add it to the post?
Not sure how?:
Добавление изображений к существующему вопросу
The beeps could indicate a fault. The number of beeps, as BurtBen suggested a recording, might help us diagnose the issue.
How old is the laptop?
из JnCA Поделиться
