Руководства по ремонту и информация по разборке Mac Pro четвертого поколения, выпущенного в декабре 2019 года.
Mac OS Recovery Fail
Hello,
Computer: Mac Pro 2019 Intel Processor
Problem: I am running into a problem where I am unable to enter macOS Recovery over the internet.
Originally, I wanted to erase my hard-drive to reset my mac. However, I forgot to use Bootcamp Partition to delete the Windows version. When I was in the macOS Recovery downloading the latest version of macOS Ventura, my internet shut down and the download could not continue. When I restart my mac trying to start up using macOS Recovery over the internet. I was prompt with this message.
Recovery
Your PC/Device needs to be repaired
Error Code: 0xc0000225
I was hoping to bring it into apple and them diagnose but I wanted to see if I can find solution at home first.
Thanks,
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Try in recovery mode and quit the recovery tools and check if gives you an option to restart.
It should ask you to choose a disk to boot on, check if MacOS or Windows comes up, select MacOS and do a partition.
Hope this works!
Был ли этот ответ полезен?
Счет 0
I find using the internet recovery has its good days and bad 😞 Apple tends to forget about updating it. And if you have a no longer supported system and OS version it uses forget it!
I would creat a bootable OS installer with the MacOS you are currently using, of course you need a working Mac to do that😩!
Get a 32GB thumb drive and try to hunt down a friend with a Mac to help you if you don’t have a second Mac.
Here’s the needed OS file How to download and install macOS and here’s how to make the bootable image Create a bootable installer for macOS
Счет 0
Добавьте свой ответ
Young буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 4
За последние 30 дней: 23
За все время: 969
