Bajaj Discover — это бренд мотоциклов от компании Bajaj Auto. В настоящее время существует четыре варианта модели Discover: Discover 100 DTS-Si, Discover 125 DTS-i, Discover 125ST и Discover 150 DTS-i.
Start problem Bettry full charge Handle problem Kick problem
  • Start problem
  • Bettry full charge
  • Handle problem
  • Kick problem
Это хороший вопрос?
Счет 7
4 Комментариев
Start problem repairing
из Поделиться
@sameertagala @vaibhavtaliyan we really need more history than just 3 words. If you are seriously wanting some help, you need to be more descriptive. At minimum we need to know what Bajaj model your bike is. Complete model number please. Then we need to know what the actual starting problem is. Then you need to tell us what you have already tried to fix this. Give it a try. You'll see that people will actually work to find a solution for you. We just have to know what the problem is.
из Поделиться
Excilater not work bike cut out always
из Поделиться
@parmmehmi what year, make and model? what have you checked? Since it cuts out, it could be related to your carburetor, the ignition or the fuel supply.
из Поделиться
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Start problem solve for bike pulsar
Был ли этот ответ полезен?
Счет 2
If you are facing starting problem in pulsar So there is chance of problem in CDI coil, spark plug , spark plug cap, petrol Over flow and engine head.
Before you spend any money first try on petrol Over flow, you just do off petrol cock when you park your bike and when you go back on bike then on this cock.
If you will not get result then check spark , plug and current and do work on CDI.
Счет 1
Are you getting a spark from your plug when you put it against cylinder head, have you tried putting 5 ml petrol into cylinder head
Счет 0
{Bike's Solution}
1: Bike ka pulk saaf kare pahle
2:Air filter ko saaf kare
3: air mixture 🔩 ko set kare
Счет 0
Добавьте свой ответ
Sameer Tagala буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 34
За все время: 2,705
