The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
2 Комментариев:
@usmansidat how high is your fuel consumption? What exact year and engine size is your Honda? What have you checked and what have you tried to fix it? Things like tune-up, spark plug change etc?
Do you have a check engine light on? A sudden significant increase in fuel consumption is likely an unexpected consequence of another problem you have.
из oldturkey03
из Chaya Milchtein
