How to change charge cavity
Это хороший вопрос?
Счет 2
2 Комментариев:
I am terribly sorry but I am not sure what you are asking. It is possibly a language barrier, if English is not your first language, but that is no reason to not try and help you.
Are you referring to the battery? Or perhaps the charging port?
(Examples using a different device just to help communication.)
Example of a battery change: Замена аккумулятора Samsung Galaxy S10e
Example of a charging port change: Замена порта USB-C и платы зарядки Samsung Galaxy S22
If it is something else, please clarify.
из
@erelectronics sounds like they mean the charge port
из
Добавить комментарий
