Nintendo DS — это портативная игровая консоль седьмого поколения от Nintendo; первая в своем роде среди всех систем с технологией двух экранов, если не считать раскладные системы Game & Watch.
Rewiring my volume control?
I have an old ds that doesn't work any more and i was wondering if i could tahe the volume control out of it and use it in my mint tin amp if so how would i wire it
Это хороший вопрос?
Счет 1
2 Комментариев
Can u post pictures of the wires in question? Both, if possible?
из
If you know how to use an ohm meter, you should be able to figure it out, However...
It is not as 'cool' but buying the right value (both resistance and power rating) is probably a better bet. For not much money you can get the right part with all the mounting hardware.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Give it a try. Take the potentiometer out of the DS carefully. It most likely will have three terminals. Connect your audio source to the right most terminal, connect the audio input to the mint tin amp to the wiper (the center terminal) and ground to the the left most terminal.
This is a fairly generic statement, assuming the pot in a DS looks like the kind in other toys. Basically you have a resistor with a sliding center tap. So you can use an ohm meter to determine which terminal is which. If the volume goes down when your expecting up, reverse the wires from left to right, leave the center tap the way it is.
Был ли этот ответ полезен?
Счет 1
I don't believe that you will have much success.
-Me-
Счет 0
Добавьте свой ответ
joshua буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 12
За все время: 2,736
