Оригинальный Motorola One, не путайте с One Power или One Action. Номер модели XT1941.
Phone not holding charge
I bought a new battery but my cell phone can't stand being unplugged, I took it to a service center to check the battery level and it's perfect, what could be the problem with the cell phone not holding the charge?
Это хороший вопрос?
Счет 0
3 Комментариев:
@leonardoga81282 How did they check this " the battery level and it's perfect" does that mean they checked the battery voltage? What did they check? Does your phone turn off immediately when you unplug your charger? What are the exact symptoms your phone is having?
из
I don't know for sure how they checked, but they said the battery is brand new. My phone dies immediately when I take off the charger, I'm using the old battery right now and it lasts for like an hour, but the brand new lasts nothing
из
@leonardoga81282 does it die as soon as you disconnect the charger with the old battery as well?
из
Добавить комментарий
1 ответ
@leonardoga81282 this "dies immediately when I take off the charger, I'm using the old battery right now and it lasts for like an hour" sure sounds like a bad battery. New or not, if it does not work, but the old one does, it's your battery. Get another replacement and make sure that it is the right model battery for your phone. Let us know what happens when you install it.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Leonardo Garcia Gerytch буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 315
