Бюджетный настольный ПК от Acer, выпущенный в 2006 году.
Desktop shows blinking screen and does not boot
When turned on it does not boot and has small disk in the driver, probably boots from it
Это хороший вопрос?
Счет 10
3 Комментариев:
my coputer is slow
из
C P U not start
из
My CPU not starting when switched on
из
Добавить комментарий
2 Ответов
@talibhassan explain this "has small disk in the driver" a bit better. Also verify for us that your computer is a T180.
You have not told us if this computer has worked for you before and if anything happened to it. The more details you can give the better your chance of getting good answers.
The very first thing you would want to do is to try and access the BIOS. There you want to check the boot order and if there is a boot device found. You could always try a bootable USB drive and set the boot order to USB. See if that boots up.
To enter the BIOS you will need to pess the Power key to power on the system. As soon as the first logo screen appears, immediately press the F2 key to enter the BIOS.
It does sound like your computer can't find the OS which could be HDD failure, but you need to see in the BIOS if it is found.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Good site you've been doing some research
из
Desktop start not display
Счет 0
Добавьте свой ответ
Talib Hassan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 11
За последние 30 дней: 62
За всё время: 3,360
