No boot device available
My computer will not start up. Cannot find boot device. What is most likely cause?
Это хороший вопрос?
Это хороший вопрос?
@erichinkle most common issue would be a failed hard drive.
On startup hit the F2 button (may take a couple of times) to enter the BIOS. Once you are in the BIOS check for a boot devices. See if your computer can still find your HDD.
You could also try and set the boot order to USB and get a bootable USB drive. Boot from that and try to access your HDD. I use Puppy Linux Live CD installed on a USB flash drive and use it to gain access.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 21
За все время: 408
