Display vertical and horizontal lining issue
Display lining issue no clear picture what is problem
Это хороший вопрос?
Счет 1
7 Комментариев:
@ratishulvekar post a picture of what your screen shows you, with your question. We need to see what you see Добавление изображений к существующему вопросу
из
To add to the above, we need a picture of the issue but if its really thin, maybe single pixel wide, lines that are (from what I've seen personally) usually green, red, or black - its likely that strip of pixels failing or physical damage. Which isn't often repairable without replacement of the LCD screen itself as far as I know, unfortunately.
Can't help diagnose without a picture though.
из
I have the same horizontal line issue
из
I am facing horizontal line issue can it be repaired or I have to change the panel.
из
@upasanadutta post a picture of what your screen shows you, with your question. We need to see what you see Добавление изображений к существующему вопросу
из
Показать ещё 2 комментариев
Добавить комментарий
