Shutdown after battery replace.
Today I replaced battery on my mb pro 15 2015 and after not longer work with small load it shuts down. I open my drive app and try to load some files, after that mb turn off like as a battery not charged. This happens only without charging.
Is it problem with battery or I should do something with settings? Nvram and SMC has been reset
Это хороший вопрос?
Just so I am sure I understand correctly, does it work properly when you leave it connected to a charger?
из Alisha C
I would install this useful too CoconutBattery take a snapshot of the apps main window and post it here so we can see it while connected to the charger. That is if you re-installed a fresh battery which you do need as the charger is not rated to support the system without the battery.
из DanJ
