Смартфон среднего сегмента от Realme, выпущенный 14 сентября 2020 года. Работает на базе процессора Snapdragon 720G, оснащен до 8 ГБ оперативной памяти и 128 ГБ встроенной памяти, а также имеет 6,4-дюймовый Super AMOLED-экран.
Power bottom not working
Pawer bottom not working
Это хороший вопрос?
Счет 11
7 Комментариев
Change display change
из Поделиться
@syedrehan44267 why would you change the display if the power button isn't working?
из Поделиться
Pavar batan Working not
из Поделиться
Power button not working
из Поделиться
Phone power button is demage
из Поделиться
Показать ещё 2 комментариев
Добавить комментарий
6 Ответов
Наиболее полезный ответ
. Open the back door first (pasting by gum)
. Unscrew all
. Open the backcase carefully
. Remove all connected strips
. Remove the mother board
. Remove the power strip.
Был ли этот ответ полезен?
Счет 2
@kingashis you are not giving us a lot of information. All you could do is give us 4 words to try and help you? It would be nice to know what you have tried to fix this. Or at least to let us know what you have checked.
First off you want to reboot your phone to eliminate any temporary glitches. Press and hold the volume down button and the power button simultaneously for about 10-15 seconds
After that you need to make sure that you have the latest update for your firmware. Check on that by going to Settings > About Device > Software Updates > Check for Updates.
Next clear the cache by going to To clear storage cache, proceed to ******Settings > Storage > Cache Storage
Now if none of that work(ed)s you may have to replace the power button flex. For that use this guide
Replacements are available at plenty of online stores. Just do a search and select a vendor that appeals to you.
Since iFixit does not yet have a guide, it would be great if you could help out. While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Счет 0
Well I will suggest you to check out the following video: https://www.youtube.com/watch?v=1TnPiP_0...
Счет 0
Yes phone power botten not good work
Счет 0
Update (11/12/25)
Счет 0
Power button not working phone off on
Счет 0
Добавьте свой ответ
king Ashis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 19
За последние 30 дней: 38
За все время: 2,949
