My videocon ac showing e5 error
Some time My videocon ac showing e5 error
Это хороший вопрос?
Счет 0
3 Комментариев
code L6 what's meaning
из
E5 error videocon ac and out door not start problem
из
@hasnainsha87010 did you check the answer?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@sanjeevver27557 looks like your videocon ac is actually a split air conditioner. The error code E5 is an indoor fan fault. This could be a failed indoor coil temp sensor as well as a bad fan. Since it is intermittent I would replace the sensor first
Take a look at this video and see if it provides you with a resolution of this issue.
While you work on your AC, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Sanjeev Verma буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 35
За всё время: 2,982
