Power Mac G5 — это настольный компьютер, впервые выпущенный корпорацией Apple в 2003 году. В этом руководстве рассматривается процесс ремонта Power Mac G5 от Apple (номер модели A1047, EMC 2061), выпущенного в 2004 году. Он был снят с производства в 2006 году в рамках перехода на процессоры Intel — сначала для разработчиков, а затем и для рядовых пользователей.
Possible G5 graphics card replacement?
Hello! I'm was trying to pull all the data off of an old Power Mac G5, and while the computer powered up just fine (fan running, audible responses to key strokes, etc.), I discovered the monitor (an old Mag InnoVision LT976s from 2003) no longer displays anything. To be clear: the monitor powers on, and displays options, etc. But it indicates it can't detect a signal from the computer.
Undaunted, I bought some new cables (VGA to DVI, DVI to DVI, etc.), and even (thanks to this site) tried my hand at removing the (very dusty) video card, wiping it off a little, and putting it back in. No dice.
As such: is the only option here to hunt down a new video compatible with an old G5? If so, does anyone have recommendations on what to buy? Note: I only need it to help me get the data off the computer, not to work particularly well or for the long haul — so it doesn't need to be particularly nice.
Any recommendations are welcome!
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
You're going about it the hard way if all you want is the data. It's a serial ATA drive. Just pull the drive and put it in an external enclosure.
Here are enclosure options (make sure you get one for a 3.5" drive):
https://www.amazon.com/s?k=sata+external...
Here's how to pull the drive:
Замена жесткого диска Power Mac G5
Был ли этот ответ полезен?
Счет 5
5 Комментариев:
Oh! This is super helpful.
Out of curiosity, I assume it'd be a bit more work on the back end to organize the data coming off the hard drive like that, yes? (I'm not really concerned about that, just curious — I've never worked with a hard drive pulled straight out of a computer before.)
из
what computer are you transferring to or reading the drive froM?
из
@mayer 14 inch 2021 MacBook Pro
из
You will need a way to get from the external enclosure to your MBP. This cable will do that:
https://www.amazon.com/AmazonBasics-Type...
из
Awesome. Thanks!
из
Добавьте свой ответ
Shalam буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 8
За последние 30 дней: 23
За все время: 564
