Жесткий диск SATA 3,5" объемом 250 ГБ, выпущенный компанией Western Digital.
Hdd is not getting detected
When i turn on the pc harddisk turns on and then turns off after 10-15 seconds. I want to recover my data from that disk. I tried to contact manufacturers of that disk but they say that disk is a copy and not a genuine one. I also tried to connect that drive to other pc but there also not getting detected
What should i do ?
That data is very much important to me. Please help
Это хороший вопрос?
Счет 10
1 Комментарий
I have already recovered some HD's by removing the electronic board and resoldering it with the hot air rework station.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@khushaldhumane explain to us what this means "they say that disk is a copy". There are two possible failures, The controller board or the mechanical part. If it is mechanical, you want to leave your hands off and send your drive for data recovery to a place that specialize in this. Those are not cheap.
For the controller issue, you could try to replace the controller board. I've done that a few times and successfully removed data from those drives. But, you will need to get the right board etc. Not always an easy find. Check this guide for what I am referring too,
Замена контроллера жесткого диска Hitachi GST Deskstar HDS721010CLA332
If you need more info or guidance, post some good pictures of your board etc. with your Question. that way we can see what you see.
Добавление изображений к существующему вопросу
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
Hitachi GST Deskstar HDS721010CLA332 Hard Drive Контроллер Изображение
Инструкция
Сложность:
Умеренно
20 minutes
Был ли этот ответ полезен?
Счет 2
I am also stuck in the almost same situation. In this case, put your HDD in the sun for around 1 hour, then let it cool down for 10 minutes, and then insert it. In some cases, the HDD is fully recovered, and in some cases, it shows up in your PC for around 5-6 hours or a day. I recovered my data with this method.
Счет 0
Добавьте свой ответ
Khushal Dhumane буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 26
За последние 30 дней: 145
За всё время: 3,819
