Информация по ремонту и разборке Pixel Fold, первого складного смартфона Google. Выпущен 27 июня 2023 года.
Where can I get camera glass replacement
I woke this morning to find a hole perfectly above my camera so that the lens is exposed the camera still works except blurry between 2x-5x so my question has two parts first will the blue go away with a new camera glass and where can I get the glass? Thanks in advance
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
I couldn't find OEM replacement glass but I did find tempered glass lens protectors.
https://www.amazon.com/dp/B0C5R3WFN6?ref...
I then followed the Pixel 7 Pro camera glass replacement. Glue released very easily with rubbing alcohol. I used masking tape to pull any loose shards off throughout the procedure. Used small spurts of canned air to clean everything out once the glass was removed. Turned out pretty good and have no loss of function.
https://www.youtube.com/watch?v=Y1WYIia-...
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Steven Keck буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 36
За всё время: 1,490
