Xiaomi Redmi Note 10 Pro — это смартфон среднего ценового сегмента от компании Xiaomi, выпущенный в марте 2021 года. Он оснащен 6,67-дюймовым AMOLED-дисплеем, основной камерой на 108 Мп, боковым сканером отпечатков пальцев, аккумулятором емкостью 5020 мА·ч и работает на процессоре Snapdragon 732G.
Why my fingerprint does not work
Это хороший вопрос?
Счет 3
7 Комментариев:
Not show fingerprint option on setting and try all options are setting does not show and work fingerprint option
из
How could i use fingerfrint senson
из
Why my fingerfrint does not work
из
I have this problem too
из
Показать ещё 2 комментариев
Добавить комментарий
2 Ответов
@bikashsah I suggest that you start by restarting your phone. Next, you want to check if your phone's software is outdated. Go to "Settings" > "Software update" and check for any available updates. Then you have to consider that Xiaomi may have turned the fingerprint sensor software off. Xiaomi has had a lot of bugs with their fingerprint sensor and software. Of course, then there is also the possibility of this being a hardware issue. If your sensor has failed, your software will most likely not find it.
Since iFixit does not yet have a guide for this, use something like this guide to replace it. A new sensor flex is readily available at many online stores. Use a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Был ли этот ответ полезен?
Счет 0
Try updating your fingerprint extension service. The update is in this site....
https://www.apkmirror.com/apk/xiaomi-inc...
Счет 0
Добавьте свой ответ
Bikash Sah буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 28
За последние 30 дней: 88
За всё время: 7,312
