Infinix Hot 10i — это бюджетный смартфон с экраном 6,52 дюйма и аккумулятором емкостью 6000 мАч, выпущенный в мае 2021 года.
I forgot my pattern
How to for.at may infinix phone
Это хороший вопрос?
Счет 2
2 Комментариев
لكنني عمله حروف انجلزي
из
i have forgotten my pattarn
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
إذا كنت لا تستطيع فهم الإنجليزية أو تواجه مشكلة في اللغة، لقد أعدتها باللغة العربية، ما عليك إلا التمرير لأسفل الصفحة.
I’m sorry to hear that you forgot your pattern. There are some possible ways to unlock your Infinix Hot 10i phone, but they may involve erasing your data or resetting your device. Here are some options you can try:
  • If you have set up a Google account on your phone, you can use the “Forgot pattern” option after several unsuccessful attempts. You will need to enter your Google username and password, and then choose a new pattern.
  • If you have enabled the “Find My Device” feature on your phone, you can use it to remotely erase your device and remove the screen lock. You will need to sign in to your Google account on another device, and then select “Erase device” option.
  • If you have a backup of your data, you can perform a hard reset on your phone using the recovery mode. This will erase everything on your phone, including the screen lock. To do this, you need to turn off your phone, and then press and hold the Power and Volume Up buttons until you see the Infinix logo. Then, use the Volume buttons to select “wipe data/factory reset” option, and confirm with the Power button.
You can find more details and instructions on how to unlock your Infinix Hot 10i phone in the links below:
I hope this helps you solve your problem. Please be careful not to forget your pattern again in the future. 😊
if you cannot understand or having trouble ive prepared it in arabic
أنا آسف لسماع ذلك، لقد نسيت نمط هاتفك إنفينيكس هوت 10i. هناك بعض الطرق الممكنة لفتح قفل شاشة هاتفك، ولكن قد تؤدي إلى محو بياناتك أو إعادة ضبط جهازك. فيما يلي بعض الخيارات التي يمكنك تجربتها:
- إذا كنت قد أنشأت حساب Google على هاتفك، يمكنك استخدام خيار "نسيت النمط" بعد عدة محاولات غير ناجحة. ستحتاج إلى إدخال اسم المستخدم وكلمة المرور الخاصة بحسابك على Google، ثم اختيار نمط جديد.
- إذا كنت قد قمت بتمكين ميزة "العثور على جهازي" على هاتفك، يمكنك استخدامها لمحو جهازك عن بعد وإزالة قفل الشاشة. ستحتاج إلى تسجيل الدخول إلى حسابك على Google على جهاز آخر، ثم تحديد خيار "مسح الجهاز".
- إذا كان لديك نسخة احتياطية من بياناتك، فيمكنك إجراء إعادة ضبط كاملة على هاتفك باستخدام وضع الاسترداد. سيؤدي هذا إلى محو كل شيء على هاتفك، بما في ذلك قفل الشاشة. للقيام بذلك، تحتاج إلى إيقاف تشغيل هاتفك، ثم الضغط والاحتفاظ بأزرار الطاقة وزر التحكم في مستوى الصوت لأسفل حتى تظهر شعار إنفينيكس. ثم، استخدم أزرار الصوت لتحديد خيار "مسح البيانات/إعادة ضبط المصنع"، وتأكيد ذلك باستخدام زر الطاقة.
يمكنك العثور على المزيد من التفاصيل والتعليمات حول كيفية فتح قفل هاتفك إنفينيكس هوت 10i في الروابط أدناه:
- [Unlock Infinix Hot 10i with Forgotten Password or Pattern Lock](^6^)
- [How to Unlock INFINIX Hot 10i? , how to - HardReset.info](^7^)
- [Infinix Hot 10i Pattern And Password Unlock | Infinix Hot 10i Hard Reset](^3^)
آمل أن يساعدك هذا في حل مشكلتك. يرجى الحرص على عدم نسيان نمط هاتفك مرة أخرى في المستقبل. 😊
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Ahmed mohammed буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 41
За все время: 975
