Its hinge is broken and cracking.
Это хороший вопрос?
Hello, I’m sorry to hear that your HP Laptop 14-dk1022wm has a broken and cracking hinge. This is a common problem that affects many laptops over time. There are a few possible causes and solutions for this issue:
You can find more information about your laptop’s parts and components on this page. You can also find more setup and user guides for your laptop on this page.
I hope this helps you with your HP Laptop 14-dk1022wm hinge issue. 😊
Был ли этот ответ полезен?
@kingofspades you need to check your AI's links. "by following the instructions on this guide " There is no guide. It links to the HP Customer Support site.
@oldturkey03 I see! thank you for pointing out my mistakes!
@donaldcrump besides all the technobabble from the AI in the preceding answer, all you have to do is to download the service manual for your computer from here The hinges are listed as part of the display assembly. Page 64 will tell you how to work on those as well as giving you the part number for the replacements etc. If the hinges are too broken, they may even have cracked the top case, so you may need to replace that as well. Sometimes it helps to post images of the damage. That way we can see what you see and hopefully guide you further.
За последние 24 часов: 2
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 409
