LCD Backlight - SMD fuse replacement
Hi,
I think i've blown the fuse during the replacement of the LCD Screen.
Due to that the Backlight of the screen doesn't work any more.
Does anyone knows the specifications of the fuse I have to replace replace?
The Mainboard looks equal to the T580 smd fuse replacement video on youtube, that I found.
Lenovo ThinkPad T580 Disassembly and LCD Screen Backlight Fuse Repair - YouTube
Where can I find the mainboard name to be 100% sure?
TYPE is 20LC-S10800.
Это хороший вопрос?
@adlerjohn, it'll be stenciled on the board. The opposite side of where your RAM and CPU is located. IF you take the board out and flip it over, you should clearly see it. Looks like the T580 uses a LTS-217812-1
Have you measured the voltages on your display connector? That would give you an idea if this is a voltage issue or a backlight strip issue. Post good clear large pictures of both sides of our board with your Question. Добавление изображений к существующему вопросу
из oldturkey03 Поделиться
