How to break pin lock
Это хороший вопрос?
If you forgot the pin code you can do a Hard reset via the recovery menu options which will wipe the phone and remove the pin lock however you will need to login to your Google account that was previously used on the phone to continue to setup your phone after the reset is done.
To do a hard reset via the recovery menu please use the button combination as follows:
With the phone powered off, HOLD (Power + Vol ⬆️ + Home) buttons until you see the Samsung logo on the screen then release the buttons. The phone should now be in recovery Menu. From the recovery menu use the Vol+ & Vol- buttons to select the option you want and use the power button to select it.
Был ли этот ответ полезен?
If you forget your previous Google account that was used to sign in on this phone
I have this problem
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 34
За все время: 947
1 Комментарий
Pattern removal
из Fikile
