Руководства по ремонту и инструкции для MacBook Pro 13" с процессором Apple Silicon 2-го поколения (чип M2) и 13,3-дюймовым дисплеем Retina. Модель A2338. Впервые выпущен 15 июля 2022 года на конференции WWDC 2022 одновременно с MacBook Air M2.
Screen Problem, blurred lines at bottom of screen.
Hello,
My Mac have developed some blurring at the bottom on the screen. It covers the entire width of the screen and is about 1/4" high.
I took it into Apple and they said it needed "screen controller" repair costing about $600.
Has anyone else had this issue and was able to perform a fix themselves.
Thanks
Andrew.
Это хороший вопрос?
Счет 0
1 Комментарий:
Sadly its out of warranty !!!!!!
из
Добавить комментарий
2 Ответов
Ouch! Your system should still be under warranty!
Double check if it is, then go to anther Apple store or dealer as this should be a free repair!
Unless there is visible damage around the displays chin area I can’t see any reason to be denied.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
из
@andrewusherwood - If its just outside the window by a few weeks I would still press Apple, But you need to lean on them a bit. Be pleasant but firm, escalate it up the food chain, I'm sure you should be able to get this fixed for free!
из
I have the same problem, just just happen just I made an upgrade to Sonoma, I a few weeks after. Now, I don't know if its is hardware problem, or is it an software/driver issue. How can I tell, and take appropriate. I reverted to the original OS that come with the laptop, but the issue still persist.
Hope some can help..
Thanks
Счет 0
1 Комментарий:
@georgetuges - Plug in an external display, if the image is clean on it, it tells us your internal displays logic is damaged and you likely need a new display assembly.
из
Добавьте свой ответ
Andrew Usherwood буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 27
За всё время: 1,010
