2100: detection error on HDD
It failed to start just bring word2100: detection error on HDD
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@fik87924 that is the error that comes up when your computer's BIOS is trying to access the drive and it can't. Could be related to a bad connection between the drive and the motherboard, or it could be a bad drive. I would remove the drive and then reseat it. Give it a try. If that does not work, you may have to consider a new drive.
You can download the hardware maintenance guide for the computer you listed, from here I will help you to work on your Lenovo.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Fik буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 18
За все время: 656
