Руководство по ремонту и устранению неполадок для беспроводной мыши Apple с поддержкой Multi-Touch. Номер модели A1657 или A3204.
Magic Mouse 2 in not connected
When I switch on the Magic Mouse 2... on screen says "Mouse Connected". Few seconds later, on the screen says:" Connection Lost" I'm thinking about the battery of the mouse( 2 years now, non stop working). But the battery is a common on. Thank you in advance for your help. Panagiotis Badalakis
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
While its possible the battery has failed, I would first give the mouse a good over night charge (better than 8 hours) use your iPhone charger as your system likely won't let your mouse charge when in sleep mode.
In any case heres the guide and the battery info Замена аккумулятора Magic Mouse 2
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
thank you very much, dear dan. i saw that the battery costs about 85$, and the new one round 100$. does it worth it?
из
@panagiotis81413 - For some people that $20 does. For me it’s the principal of throwing away a still functional device when it only needed a battery. We’ve become too throw away wasting resources.
But, before you make that jump make sure the battery is truly bad. Often times it’s just not getting a good charge.
из
Добавьте свой ответ
Παναγιωτης Μπανταλακης буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 30
За все время: 474
