Nintendo 2DS — это портативная игровая консоль, разработанная как бюджетная версия Nintendo 3DS с практически идентичным аппаратным обеспечением, но без функции отображения 3D-контента на верхнем экране.
2ds camera error has accured
My 2ds camera works in the AR CARDS app but not in the 3ds camera and quick cam menu
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Sounds like the camera app itself is broken. Try safe mode. If that doesn't work, you'll probably have to factory reset it unless you have CFW.
If safe mode failed and you have CFW, you can try deleting the camera app, then updating the system to restore it. Launch FBI, then go to Titles > Nintendo 3DS Camera > Delete Title And Ticket. Press A to confirm, then update the console (you can use safe mode or the regular system update). The update will redownload and install the app, leaving you with a working camera
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
The 2ds I had, I had sold, thanks for the answer I will use this information if I come across this again. I will accept your answer since it “worked”
из Поделиться
I did this, now instead of crashing it leaves a message saying "an error has occured, hold down the power button to reset" after reseting it still just has this message.
The error popup only happens when i try to use the inner camera, the outer works fine. I have a new 2ds xl.
из Поделиться
Hi!
In this case you most likely need to replace the inner camera. If you need guides, please let us know!
из Поделиться
Добавьте свой ответ
Sqwerks буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 12
За последние 30 дней: 93
За все время: 3,465
