iPhone SE 3-го поколения был анонсирован 8 марта во время мероприятия Apple «Peek Performance». Он оснащен процессором A15 и 4,7-дюймовым ЖК-дисплеем, как и его предшественник, iPhone SE 2020 года.
Texts are going through as emails
My text messages keep go through as emails. When I go to settings, messages, iMessage. I can’t choose the phone number option. It doesn’t save it and goes back to the email. Does anyone have any suggestions? The calendar is set to automatically update as well
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
@johnmac22911, Not sure if you turn your phone off after updates or even every few weeks to let it reset. But, it's a good practice to do so.
The first thing I recommend doing is shutting off your phone for 5 minutes. Then turn it back on and try and send a text message. See if it sends it from your phone number. Sometimes doing this simple reset can fix the issue.
This next thing might seem obvious, but I have to ask. Is your phone using a cellular network? (Sometimes folks use their phone on WiFi only). If it's on a cellular network, then I would go back into the Settings > Messages > Send & Receive > Click on the Addresses and double check that the, Start New Conversation From box with your phone number is the one that is checked.
If there is a check mark next to your email, then uncheck it. Then click out of messages to go back to settings. Then try sending a text message to test if the settings work.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thank you for your reply. I tried everything mentioned. The issue seems to be when I uncheck my email under the messages portion of settings.
My phone number shows, however, I’m unable to select it. The wheel simply spins next to my phone number then stops. A check mark doesn’t appear.
из
@johnmac22911, you're welcome. I'm sorry this didn't work. Have you tried turning Messages off and then back on again?
Go to Settings > iMessage > Toggle Green Switch off.
In my experience it's better to turn iMessage off and then press the back button to go back to the main settings menu. Then wait about a minute and then return back to the iMessage settings to toggle the switch back on.
из
Добавьте свой ответ
John Mac буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 329
