Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
Bootloop after battery replacement
Hello, I recently replaced my battery and after doing so my phone became stuck in a bootloop. I tried restoring via iTunes but it gave error code 9. I looked at other posts on this forum and assume I broke a resistor I would like to try resoldering it but I can't find the damage. It also keeps popping out and another flex cable for my atenna (I think) also keeps popping out. Pictures added below.
Battery:
Wifi/BT:
Any help would be much appreciated.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Hello, could try to disconnect your earspeaker flex cable and try reboot the phone? It is very common and easy to damage the proximity sensor that is on that and cause boot loop.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Hi, unfortunately that isn't the problem the cable from my earspeaker isn't connected since I replaced the screen but didn't put over the speaker yet.
Thanks for your reply
из
I had a similar issue after a battery replacement once. The bootloop can be frustrating. In my case, it turned out to be a loose connection inside. I had to double-check all the cables and make sure they were securely attached. Also, try cleaning the connectors with some isopropyl alcohol if you can.
Счет 0
1 Комментарий:
Do you remember where the loose connection was? Battery flex? I will try alcohol asap. Thank you for your help.
из
Добавьте свой ответ
Bermt буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 336
