Выпущенный в 2017 году, Acer Nitro 5 (модель AN515-51) — это игровой ноутбук с процессором Intel Core i7 и видеокартой Nvidia GTX 1050 Ti.
How to add more RAM
How to add more RAM to my laptop
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
Run your laptop's model number in google with "ram" in the search, do a bit of digging around. Most of the time the easiest way to find it is to unscrew the little screws on the back of your laptop (put them into a baggie, as you will need them to put back!) and gently pop off the back cover. If you have to pull hard at all, you missed screws. Look for the ram module (kinda like a thin pack of gum with a shiny wing) that is clipped into the board. There will be numbers on it kinda like (8GB 1Rx8 PC3L), search for them (google/newegg/microcenter) and simply either add a second module of the same type to double your ram if there's an empty slot, or replace all of them with a higher capacity. Always check that you put all cables back and things boot up fine before you screw everything back together.
Best of luck with your project,
Dan
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Okay, I Will try it Thanks for the answer. maybe you have some pictures to make me easy
из Поделиться
Добавьте свой ответ
Andy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 16
За последние 30 дней: 63
За все время: 686
