Solenoid Pump Stops Running
I took apart the Steam Mop. The steam heating elements works fine, so I disconnected it from the circuit. There is an issues with the solenoid pump. It begins running great then suddenly stops working. I can get it to restart and work again for the short period as long as I fully disconnect the Power supply. If I turn it off with the buttons then it doesn't restart again correctly when I power it on.
It almost seems like a capacitor might be causing an issues? Something that fills up then doesn't operate correctly.
Looking for help diagnosing this issue.
Here's a video of the pump and it's issue: https://youtube.com/shorts/xG5KXi7P5Yc?f...
Thank you,
Это хороший вопрос?
Счет 0
Добавить комментарий
