My walker is bent
Walker went over with me in it when bus braked sharply it is now bent and goes left, is there anyway or anyone to fix it?
Это хороший вопрос?
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 19
За все время: 276
The depends where the bend is but you can try to remove the wheel(s), insert a bending spring that corresponds to the diameter of the frame of your walker and try to bend it back. If you are not using a srping or something that you can insert into the hollow frame you will risk kinging the metal and woul will be worse off...
из honakrisi Поделиться
