Руководства по ремонту, инструкции и помощь по устранению неполадок для Oppo A92. Получите все необходимое для самостоятельного ремонта Вашего Oppo A92.
Lcd screen removed from phone
I dropped my phone on the floor and the lcd screen got removed from the phone
The phone was still working because it was still vibrating without the screen
How to fix
Это хороший вопрос?
Счет 4
Добавить комментарий
6 Ответов
Наиболее полезный ответ
Hi Jess,
If the screen is completely separated from the phone now, then the flex cable that connects them together has been torn off. Unfortunately, that's not repairable so you'll need to replace the screen with a new one. I didn't locate any step by step iFixit style guides for you, but there is a YouTube video showing someone replacing a screen who appears to be in the very same situation you are with the screen detached to start with.
oppo reno a72 / a92 screen replacement and disassembly - YouTube
The screen itself appears to be relatively inexpensive as phone displays go and it looks like you can get it at several sites like Amazon, eBay and AliExpress, among others, according to what works for you. Here's an example from AliExpress of one that should work.
Original for OPPO A92 LCD Screen and Digitizer Full Assembly for OPPO A92 - AliExpress
If you decide to take this on, be sure to take lots of pictures as you work and when you're done you can use them to create your very own iFixit guide to this repair! It's easy, fun, and will earn the gratitude of the community.
Create a new Guide - iFixit
Good luck, and let us know how it goes!
Был ли этот ответ полезен?
Счет 3
My phone is oppo A9 2020 no drop my phone screen is bpacky
Счет 0
You can search in YouTube how to change LCD oppo a92 to a new one
Счет 0
Display change
Счет 0
Ganti LCD dengan yang baru
Indonesian->English translation:
Replace the LCD with a new one.
Счет 0
1 Комментарий:
See the Most Helpful Answer above.
English->Indonesian translation:
Lihat jawaban yang paling membantu di atas.
из
Saya sedang tidak ada uang dan saya sangat membutuhkan hp itu
Счет 0
Добавьте свой ответ
Jess Domi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 58
За всё время: 3,102
