were is horn located
location of horn on a 96 cavalier
Это хороший вопрос?
I don't know if you've seen this (or if it was your post) but...
http://wiki.answers.com/Q/Where_is_the_h...
Answer
It's on the passenger side of the car under the front bumper, near the wheel well. If you lay down and look up under the bumer in that area you will see a small black part with a single wire coming from it. I think it's bolted in place on a bracket.
Answer
To add to the above answer,the horn on the 1996 Chevy Cavalier is located as follows: Underneath the car, look for a girdered black bar that runs across the car, directly under the radiator. On the passenger side, the L-bracket that attaches the horn is bolted with a 13mm bolt to the vertical steel inner wheel well about two inches above the girder.( The plastic wheel well panel will have to be removed first. There are nine 7mm/nine 32nds hex-head bolts holding it on ). The wiring loom to the horn is green(positive) and black(negative) inside a verigated loom tube. It plugs in at 90 degrees with a white plastic molex.
Answer
Or you can just remove the 2 bolts that hold in the passsenger side headlight, and access it from above if you don't have car ramps or something that will lift the car safely for you.
Был ли этот ответ полезен?
Thanks alot for the information.
Im still looking for the horn under the car.
Location of horn on a 1997 cavelier chevy.
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 34
За все время: 24,369
