Информация по ремонту и разборке смартфона Google Pixel 7 Pro, выпущенного в октябре 2022 года. Идентифицируется по номерам моделей GP4BC и GE2AE.
Google Pixel 7 Pro screen flicker
Replaced a broken screen on the wife's Pixel 7 pro and it worked perfect for a few months . Now if she uses it longer then about 5 minutes straight she gets some crazy screen flicker and the screen will slowly almost white out . Trying to figure out what the next step is. Faulty screen? something else broken? Maybe a setting or program causing overheating of cpu ? any help would be appreciated
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Hi Keenan,
I have to agree with @ihave0idea that it's likely your replacement screen has failed. Whether that's due to physical or liquid damage, or an inherent defect in the screen, you'll probably never know. If it was a genuine Google replacement part (like what you'd get if you bought it from iFixit), then I'd lean toward the defective part diagnosis myself, as I've noted a disturbing tendency for genuine Google parts to have an unacceptably high defect rate.
It would probably be worth your time to back up the phone and try restoring it to factory settings and see if that has any effect on the problem. If not then you're almost certainly looking at having to replace the screen yet again. Given that your screen is only a few months old, it might be worthwhile checking with the vendor on their warranty policy. For example, if you bought it from iFixit then it has a lifetime warranty and would be replaced if found defective. You can check with them by emailing support@ifixit.com.
Был ли этот ответ полезен?
Счет 1
Likely the screen was defective, suggest you get a new one
Счет 0
This is an important learning experience for DIY screen replacers. Keep your old screen if it isn't completely useless. You could now switch back to the old screen and see if it operates correctly. Possibly disassemble the phone and clean the connector to the display w/ isopropyl alcohol before getting a new one.
Счет 0
Добавьте свой ответ
Keenan Dowker буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 33
За все время: 1,236
