Turns very very slow
Dji mini 2 turns very slow . Doesn't matter what speed it's in. I adjusted the settings and still turns slow
Это хороший вопрос?
Это хороший вопрос?
The question is a bit out of date; did you solve the issue?
Normally if the drone starts up okay with proper selftest beep and easily takes off, then it would most probably be a RC problem/cause. You can try using LITCHI as another way of controlling your drone (and putting your RC in 'normal' mode). Compare this and draw your conclusions....
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 14
За все время: 200
