Ховерборд Hover-1 Chrome оснащен встроенными Bluetooth-динамиками. На этой странице представлена информация о различных моделях HY-CHR.
Strippted screw on a hoverboard
How to fix a stripped screw on hoverboard
Это хороший вопрос?
Счет 0
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Yeah, so a trick I've found useful is sticking a rubber band between the screwdriver and the stripped screw. It gives you a bit more grip to turn it. And if that doesn't work, you could try using a slightly bigger screw if there's room in the hole.
Был ли этот ответ полезен?
Счет 1
A variety of suggestions in the Restarters wiki at https://wiki.restarters.net/Rescuing_Dam...
Счет 1
Is it stripped at the screw's head where the screwdriver goes? Or is it stripped inside the device where the screw threads are?
Счет 0
2 Комментариев:
The head is stripped
из
Thank you for clarifying your screw situation so we can answer
из
@siuuffv depends on the diameter of the screhead. If it is large enough use a drill. Choose a bit that is about 2/4 the size of the dia,etr of the screw head and then gently drill deep enough until the screwhead will separate from the rest of the screw. Then, once you have the case apart, use a pair of pliers to remove the leftover stub. Hardest part is to keep the drill steady and as centered on the screwhead as possible so it does not run off.
Счет 0
Добавьте свой ответ
Siuu ffv буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 445
