Ноутбук Acer Nitro 5, выпущенный в 2019 году, оснащен 8 ГБ оперативной памяти (с возможностью расширения до 32 ГБ при наличии подходящих комплектующих) и клавиатурой с красной подсветкой.
How to replace screen?
My screen went all black after someone replaced and I don’t like how they did and I was wondering if I could do it myself
Это хороший вопрос?
Счет 1
1 Комментарий:
Never replace a screen without disconnecting both the battery and the charger first!
из
Добавить комментарий
2 Ответов
Hi Alloy,
Luckily replacing the screen on the Nitro 5 is not too complicated!
Here is a link to a YouTube video that will show you how to do perform the replacement yourself: Acer Nitro 5 Screen replacement - YouTube
and here is a link to a replacement screen (You can also find them on eBay): Screen for acer NITRO 5 AN515-54 SERIES. Replacement Laptop LCD Screen (laptopscreen.com)
If you're comfortable going a step further, I would disconnect the Main battery which can be done by undoing the screws holding the bottom plate. This Will just lower the chances of the screen getting damaged during installation.
I hope this helps, let me know if you have any other questions :)
Был ли этот ответ полезен?
Счет 0
Please folks, translate this (portuguese to english):
O problema mais dificil que enfrento é distinguir se o problema está na tela ou no flat cable.
O notebook caiu de uma altura de 20cm...no primeiro momento, nada aconteceu, 4 dias depois começou a dar esse problema.
Счет 0
Добавьте свой ответ
Alloy L буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 25
За последние 30 дней: 106
За все время: 2,902
