Цифровая видеокамера Canon MiniDV с 18-кратным оптическим и 360-кратным цифровым зумом
How to fix the glitch camera
I have just bought a canon ZR60A, it works great but the camera somehow have glitches all over, it shows on the lcd screen and the viewfinder. When recording, it records exactly what the screen and the view finder displayed before, which mean the glitch comes from the camera itself, how can I handle this
Это хороший вопрос?
Счет 0
2 Комментариев:
@sangnguyen66374 you need to be more descriptive as to what kind of glitch. We do not know what you are referring to when you just use that term.
из
Thanks, I've added the photo for a clearer point. I actually can still see the object, it's just that it has an extra layer of glitch and noise
из
Добавить комментарий
1 ответ
@sangnguyen66374 since it "records exactly what the screen and the view finder displayed" and it shows the menu but not what you are looking at, the error is most likely in the video circuitry and not coming from the CCD image sensor or even being an LCD error. Looks like IC903 on the LCD board is responsible for the LCD signal processing and drive. I would stay there with checking the circuit. Here is the Canon ZR 60 A Service Manual and you can use that to check the LCD PCB
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
So is it possible to find the replacement part if the problem coming from the cuircuit component error as you're referencing...
из
@sangnguyen66374 I would look for an LCD PCB and see if that resolves it.
из
Добавьте свой ответ
sang nguyễn буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 13
За последние 30 дней: 36
За все время: 436
