Представлен 16 октября 2014 года, идентифицируется по номеру модели A1347 и EMC 2840.
Mac Mini 2014 missing bottom cover. is this a problem?
I have obtained a mac mini 2014 that is missing the plastic bottom plate cover. Is this a problem? Does this block airflow, and if so, would this be mitigated by adding feet to the base of the mac to give raise the device a little to allow air circulation? are there any other issues that will need to be worked around?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
I'd recommend adding the feet onto the Mac as it would allow for improved airflow into the device. But other than that I don't think it should be too much of an issue.
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
It might be just worth the expense to replace it here's the needed part Mac Mini Bottom Cover (used) $11 USD
из
Thanks Dan. I had searched for these online but had not found one with reasonable postage to Australia. I have bought this one as both the price and postage were reasonable.
из
Добавьте свой ответ
James буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 24
За всё время: 396
