Stops mid-cycle and more
Similar symptoms, never any error codes. Replaced door latch to no avail. Ran installation diagnostics, and it doesn't complete test 10 (door latch test). Just sits there like when it stops mid cycle.
Это хороший вопрос?
Счет 0
1 Комментарий:
@chimes91508 this was left as an Answer to a 10 year old question. If you would like some help with that, let us know the exact model number for your Washer. Also, give us more of the issues that you have with the washer.
из
Добавить комментарий
1 ответ
If it runs at all, the door latch must be working. However, it might be possible that there is a loose connection to it and vibration is causing it to momentarily open. If it is spade connectors, they might need tightening.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
chimes буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 12
За последние 30 дней: 24
За все время: 273
