Samsung Galaxy Watch Active2 — это умные часы от компании Samsung Electronics. Номера моделей: SM-R825, SM-R830 или SM-R835. Часы были выпущены в августе 2019 года. Отремонтируйте ваши Samsung Galaxy Watch Active2 с помощью этих руководств.
My watch screen opened up
I went swimming and i put the watch next to the pool but it fell into the pool, the screen popped out and when i let it dry it still doesnt turn on what can i do to fix it or is it gone forever?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
Depending on how it "opened up". If the screen separated completely with the watch I suggest you replace the watch completely. But even so if it slightly opened and water entered the system repairing would be of no use
Hope it helps
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
It opened up but still attached with little droplets of water which i managed 2 remove
из
Try charging it (make sure it is dry) if it turns on you are good to go(if the screen can easily stay there with no movement). If it is still not sticking back , I suggest opening it up, gently apply heat to the screen to make the adhesive sticky and try putting it back. If it doesn't work I suggest you get some of that adhesive (when I get the name I will inform you) and try putting it on.
из
Добавьте свой ответ
I5m4il7 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 21
За все время: 732
