Repair information and guides for the long-awaited refresh of the popular MacBook Air, featuring Intel's Core i5 processors, an updated Retina Display, and numerous other changes and updates that was released on November 7th, 2018.
Keyboard not working after battery replacement
I replaced the battery using the ifixit replacement, tooks & kit. No problems except now the keyboard doesn’t work, except the power button. I even went through the process again, still doesn’t work.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
It sounds like there's a problem with the trackpad flex cable (possibly where it plugs into the top case underneath the main logic board). Double-check to make sure that all parts of the trackpad flex cable are fully connected and that the ZIF connector latches are fully latched down. This cable has to be functional and correctly installed in order for the keyboard to be functional. Good luck!
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Thanks! I did manage to do this, just went back and was not as delicate to make sure everything was fully connected. Then I couldn't figure out how to delete my question. But hopefully this will help someone else in the future.
из
Добавьте свой ответ
Bonne Quin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 20
За всё время: 254
