Бюджетный смартфон Realme, выпущенный 14 августа 2020 года. Он оснащен 6,5-дюймовым экраном с IPS-матрицей и разрешением 720p, процессором Helio G35 и накопителем объемом до 64 ГБ. Также модель получила третью камеру на 2 МП и сканер отпечатков пальцев, которые отсутствуют в Realme C11.
My battery is so weak
How to make my battery so strong
Make a strong battery
Это хороший вопрос?
Счет 6
9 Комментариев
My battery is run fast how to repair the battery??
из
из
Pengisian kebaterai terlalu lamban/ lama penuhnya...
из
My phone battery so weak
из
Показать ещё 4 комментариев
Добавить комментарий
2 Ответов
Наиболее полезный ответ
1. Turn on the Power saving mode
You can turn on the Power saving mode, and go to Settings > Battery > Power saving mode. When it is turned on, it will automatically optimize the performance of the phone, stop the background synchronization function and prolong the battery life. You can also adjust the items to be optimized by yourself, go to Settings > Battery > turn on Power saving mode > Default optimization and add or remove some functions.
2. Turn off applications with high power consumption
You can check which app consumes more power by Settings, go to Settings > Battery > Battery Usage, click the specific app and choose to close the apps you don't need to use temporarily.
3. Turn on the Auto select screen refresh rate (If the phone is only suitable for 60Hz, this function is not supported )
Go to Settings > search for Screen refresh rate > Auto select. The phone will switch the screen refresh rate according to the application to avoid consuming more power due to using a high refresh rate all the time.
Был ли этот ответ полезен?
Счет 2
@vishalshar99819 you can't make a battery "strong". If it does no longer hold a proper charge, you need to replace the battery. After that you can set your battery savings settings etc. but it does not make your battery "stronger". It just makes it last longer. Since iFixit does not yet have a specific guide for that, use something like thisvideo for the battery replacement.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Счет 0
Добавьте свой ответ
Vishal Sharma буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 12
За последние 30 дней: 30
За всё время: 1,391
